good evening all. I have decided to completely redo my cabinet. What I would like to know is if Game Ex has a plugin that works with a pixlecade display. So my cab will so look like the picture when the game is launched. Thanx
Copy and paste the following to your address bar to search for threads related to Pixelcade:
site://forums.gameex.com Pixelcade
ok, I got it all setup. the only problem I have is when it comes across a game there is no marquee for (Tapper) for instance is scrolls  defense command across the marquee. It's annoying. How to you get it to display a regular Mame logo instead?
May be simple. Have a file of the MAME image named for each missing marquee. I do not believe that LEDBlinky has a default image option but it is something that you could approach the author@arzoo.
Glad you got it sorted. Next you need to play with displaying hi scores for MAME games that support them.
🤔 is there a way to do this? Well for right now I'm setting up systems using Retroarch. I've got Mame & HBMame looking nice with the Bezel Project with the marquee displayed. I may or may not use model 2 & 3 jury is still out on those. Oh the PS3 and Switch emulator will be used also.
