With the latest release of GameEx easiest way is probably just to set it up as a custom emulator then use a litxml output file as a map file.
I will take a look though and see if I can do a proper emulator profile for hbmame and if there is one already make sure it is up to date.
Tried the new version. deleted original configuration. added new. all the roms still don't list. not only that they won't launch either. I'm sure it's the command line. now you say use listxml and make a map file? I'ma try that. I havent made a map file in years. I'ma go thru some of my old hard drives and see if I can find a backup of a older install, plus I need to find Daphne (she's lost) LOL
Can you attach copies of your gameex.ini and log.txt files? Might show something. Thanks.
this is the command line hbmame.exe [ROM] -ROMPATH=[ROMPATH] -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
I would also need the exact command to output the roms to a text file. is the map file option gone?
This is where the requested support files are very helpful - no second guessing where your configuration may be setup incorrectly. Thanks.
Sorry, I didnt realise you already had it setup. Your post looked like you were setting it up for the first time. My new setup worked fine for me. Ill double check if you help too but it should just be importing the profile downloading emu and pointing to your games. I was using the latest set however.
Tom :) it's never that easy. The roms are merged so game ex doesnt  know about the variants. I'ma have a look at the thread Draco posted. Also can you no longer select map files within Game Ex? I don't see the option anymore.
PS: My solution lists all roms. It does not matter if you have merged set.
Your log would really help. Maybe I messed up not including the updated files or something.
This is an updated solution for nov 2022.
Hi, i need the full log please.
The file is included in the latest install fior the latest hbmame. From that log though I cant even see if your running the latest version.
From the command line.
Mame.exe -listxml > outputmapfile.xml
Actually I can see your using the new hbmame.xml map file and new profile. What exactly is the issue. Do you have an old romset?
It needs to be run from the command line or a .bat file.
or prefix it with cmd.exe
  On 11/8/2022 at 9:06 PM, DJ Infinity said:
No Tom everything is new. it runs outside of Game Ex fine. it's gotta be something I'm overlooking
Im not able to check your paths but otherwise it looks right. It lists everything right?
Its probably the paths or extra command lines.
yes sir. and thanx for correcting me on the output. I made a batch file and got a map file. now you said remove database? I'm clear it and setup again
