[RESOLVED] Problem with "Video" menu - Crash Gameex
Hi
I've got a problem with "Video" menu. When selected, it seems to scan some drawers (not only the video path apparently) with please wait screen, and then crash to desktop.
I've tried to change videos path in case of one video could be faulty but it's the same. I've tried to use another codec pack but it's the same (note that background videos in the home menu is working )
I don't know from wich version it doesn't work anymore. It was working fine before.
I've tried without network too because i have a SERVIIO media server that could cause problem but it's the same -> crash to desktop after "please wait" screen
Finaly i've tried other theme because i use custom menu but it's the same
Any idea ?
GameEx.ini log.txt
Be sure you are using the recommended LAV codecs. I would try copying your videos to a local path and see if that remedies your issue.
The last entry in the log file
15:16:59.73  02/09/2022:  Starting Search for UPNP Media Servers
Is it correct that this log is from right after the last crash?
Yes, just after the crash. I use LAV codecs. My video directory is a local path D:\Video . I've tried another local path but it does the same thing
Its fixed in 18.21. Uploading now. I apologise for this. There has been several internal changes in recent versions. Not giving much back the userbase in the short term other than a little performance gain.
  • Rochabian changed the title to [RESOLVED] Problem with "Video" menu - Crash Gameex
  • Draco1962 locked this topic
