Can you be more specific? Also, please attach copies of your gameex.ini and log.txt files (no copy & paste) whenever reporting an issue from the version causing the error.
- Are you running the XP and 32-bit version version or 64-bit?
- Is this classic GameEx or GameEx Arcafe Edition?
Both questions that can be answered with the support files provided, BTW.
@Tom SpeirsI have both 64-bit versions of both GameEx and Arcade Edition v18.16 installed. I am able to launch AE without issue. Classic GameEx does not launch as reported.GameEx.ini
There is no new log.txt updates generated as noted by 7/2/22 date stamp. Let me know if you require any additional files.
Event viewer shows the following:
  • Draco1962 changed the title to [ATTN: TOM] GameEx 18.16 not running at all.
Same for me. I went to check Log but it doesn't create one. I try to open Gameex and it doesn't load.
Are you trying to launch the classic GameEx 32-bit or 64-bit version?
I've been using the 64 bit version.
Nothing has changed between 18.15 and 18.16. I installed the update and when I run the EXE it spins its wheels for a second and then stop. No log or anything.
I'm running the 64bit version  of  GameEx 18.16. No action at all. Does not even load into memory. No mater how many times I run the exe.
Thank you both. Hopefully this will be quick fix upon Tom's return and review of the issue.
  • Draco1962 changed the title to [RESOLVED] GameEx 18.16 not running at all.
  • Draco1962 locked this topic
