[RESOLVED] Pinballx on settings /GameEx Online userid and Password does not stick
Hello, I'm a newbie, so my question is:
Configuring pinballX to download online media I tried to configure GameEx online  on the Settings.exe to download media from the Game Manager.
I assume to use the same user id(email) and password from this forum.
Horever after I entered UserID and Password various times, gives me a sound of error, and when i change section inside the Settings, the userid and the passowrd are not saved, they do not "stick" in the field,
What Am I missing?
Thanks in advance for your help!
PinballX.iniFetching info...
After you fill in the field, did you hit next ?
Also try to launch pinballX once before you start game list manager.
You can also try Databasemanager,  it will check password as well
In the Pinball Setup WIzard I entered in the tab "GameEx Online" the userID and password and hit "next" and when I return to the "GameEx Online" Tab User Id and Password vanished. Is there a way to put the user ID and the password directly in the pinbalx.ini? Attached Logs and pinballx.ini
Thanks!
SetupWizard.logFetching info... log.txtFetching info... PinballX.iniFetching info...
Thanks!
SetupWizard.log 43 B · 0 downloads log.txt 3.51 kB · 0 downloads PinballX.ini 11.7 kB · 0 downloads
password isn't saved in the pinballx.ini, but stored in registry.
@Tom Speirs
When Reg key HKCU\Software\PinballX does not exists, the reg key will not be created and UID and PW are not stored.
If this key is created manually, the settings will be stored.
When will this reg key be created ? During install ?
@biffiam I attached a small reg file, if you double click this, it will create the reg key for pinballX.
(if you know hoe to make it manually, it is fine as well)
After creating this, launch settings.exe and you can fill in the UID and PW, clicking on next and back will show your login name and able to use it within PinballX and game list manager
pinballx.regFetching info...
  • Draco1962 changed the title to [RESOLVED] Pinballx on settings /GameEx Online userid and Password does not stick
  • Draco1962 locked this topic
