Hello all,
I discovered that whenever I run a table through PinballX, the DMD X-axis setting in the screenres.txt gets changed from 1366 to 16000 resulting in backglasses that have built-in Full-DMD to not be displayed.
Load tables directly with Visual Pinball and the screenres.txt file does not change and the Full-DMD shows up.  I have looked everywhere I could think of to find that 16000 number with no luck.  I am at a lost as to where PinballX is getting that number from and why it is even changing the screenres.txt.
Anyone have ideas?
Thanks.
You properly has set the option auto dposition directb2s in your setting.ini
Run settings.exe to change the value to no, and it will not override it.
Or set the backglass correct and pinballx will always creates the correct backglass file.
  • AndyMcDandy changed the title to [Solved] PinballX Keeps Changing ScreenRes.txt Settings
You are awesome.  Changed to 'NO' and no more changing of my screenres.txt.
Thank you so much.
