[RESOLVED] Display problems in version 18.10 using 4k TV
My current display on my TV is  3840 x 2160. Always been with all previous versions of GameEx.
Now updating to 18.10 all my fonts are overlapping. To use 18.10 , I have to change the TV resolution to 1920 x 1080.  I did change the resolution in Setup wizard. That never helped.
Is there any way around this besides having to always change my TV resolution back and forth. I don't want to be stuck with 18.09 forever.
Please attach copies of your gameex.ini and log.txt files for review with this reported issue.
Just for your awareness, Tom or someone with a large display will need to confirm the errors you are encountering as I do not have a 4K display with which to test.
- That said, are you up to date with your Nvidia GeForce drivers?
- Is the log.txt file from when you attempted to run at greater than 1080P?
- Does this happen when you use the Default - Default Theme or other themes?
The bottom screenshot is V18.09.  Everything works 100% . Both at 1080p  and 2160p and different themes.
The log.txt  and GameEx.ini are in 2160p .Video drivers up to date.  I tried different video themes. Still the same. The screen also freezes. Have sign off after loading. ctrl alt delete. frozen
Thanks for the support.
  • Draco1962 changed the title to [RESOLVED] Display problems in version 18.10 using 4k TV
  • Draco1962 locked this topic
