I use the real dmd videos to play during Zaccaria just so I dont see the blank screen.  So when I start and Zaccaria game I keep the DMD on from PinballX.  This works about 3/4 of the time, but every so often it will kill the dmd when I return back to PinballX after a game.  I'm using a pindmdv3 as my dmd device and it seems to work great for all tables, but Zaccaria.  Also I hide the dmd for all other tables except Zaccaria so maybe I'm not doing something right.  Is there a trick or exit script maybe to refresh/clear the dmd before PinballX takes over again?
PinballX.iniFetching info... log.txtFetching info...
I see during your log, dat you run fx3 with dmdext as well to mirror your dmd.
Could that cause an issue? Don't see  any error in your log
Mike, thanks for the response.  I do use DMDext for fx2 and fx3, but have a batch file kill both instances after the table is done in those 2 emulators.  I do not use any batch files for Zaccaria.  The only reason I see the dmd in Zaccaria is because I don't dim it when the table starts.  However when the table closes I do see the DMD go out for a couple seconds.  I figured that was PinballX doing something.
