I recently installed the latest versions of Visual Pinball and Pinballx along with FlexDMD and Freezy's DMD.  I have 140 table working well with the exception of an occasional popup indicating an entry point for DmwRenderGester could not be found in dwmapi.dll.  I also occasionally get a message indicating Flash.ocx could not be registered.  I included screen copies of the error popups as attachments.  If i ignore the messages thigns work fine with the exception of only being able to view the default PinballX screen on my PinDMD when in front end selection mods (probably a setup I have messed up but I haven't figured out yet.  My PinballX.ini and log files are enclosed also.
I have tried reregistering the Flash.ocx and the dwmapi.dll with no success.  Thought about reinstalling PinballX but didn't want to mess anything up worse.
Any advice would be appreciated.
PinballX.ini log.txt
What is ProcessTamerTray.exe which you launch at start script ?
The dwmapi.dll is a windows dll, and althought pinballx is generating the error , i dont think a re-install of pbx will help (but you never known)
Don't you have a spare drove where you can install a clean os(w10) and start migrating all your tables/emulators?
No spare.  Running windows 7.  It’s annoying because it is very sporadic and does not seem to harm anything except make me keep a mouse nearby to acknowledge.
I am still having issue getting my pinDMD to display rom info from pinMame during front-end table selection.  I can display a video if I put one in my Real colored DMD video directory.  Otherwise the default PinballX video screen shows.  Tables run fine once selected.
Whats the issue with it ? Just showing the pinballx video and no matching rom found ? Try to add manually from a table that doesnt show, the rom name in your database file (database manager tries to do it automatically). Save the file and retry in pinballx. I dont use it, but tested it a couple of months ago and was working fine with my pindmd3 device
Mike - adding the rom name in the database was the ticket to having pinMame display Rom information during menu.  Works like a champ and enables me to use the hide DMD option as I desire.
I wonder if reinstalling PinballX will clear my flash.occ/ dwmapi.dll issue. But hate to do a reinstall with things working so well.
Thanks for your help.  I am really pleased with my setup now.
Great that it worked!
Databasemanager can populateall of your of tables and if the author programmed the table correct it will fill in the rom.
About your other 2 issues(flash and dwmapi), i'm not sure. Tey to repair your OS. Eun SFCSCAN /NOW for exapmple..
Ok. Maybe with an update of pinballx, delete the flash.ocx before installing the update. Or if you have a spare disk, try to install w10 on it
