The big problem is that you can't run Future Pinball in normal mode and in PinEvent mode. Both settings you have to change every time in Future Pinball setup, depending on which display mode you choose. that's a pity, because under Future Pinball there are nice tables ...for that I haven't found a solution yet
Problem : if I have the PinEvent mode (TerryRed) , then I don't see a baking glass/grill on tables that are running in normal mode - the whole thing is problematic the other way around as well
If someone has an idea without having to change the setup of Future Pinball/BAM again and again, please post it.
There seems to be only one solution at PinUPPopper....
https://vpuniverse.com/forums/topic/4928-dmdext-freezy-and-future-pinball-real-and-virtual-dmd-support/
best regards
