2 hours ago, hlr53 said:
FP will not launch from the wheel menu but OK from Game Manager? Running WIN 10 Pro.
Hmmmm, never had that issue before with FP.  Do you setup FP and PBX just like above?
Try posting about it in the General section (that more of a support section) so that more people can see it, and also try posting your log files.
  • 1 month later...
Hi,
I'm a total newb and have been trying to get BAM to work.
I've tried the default settings and then found this guide and copied these settings.  It doesn't seem to make a difference.
The tables load ok, but I only see just a part of the table, as if it is zoomed in to one part of the table by like 500% or something.
When I press "Q" it crashes.  Although I can't see what I'm doing, the other regular commands to insert coin, start, pull plunger, flippers, etc all seem to work fine.
Tables work fine when not using BAM.
Any suggestions would be greatly appreciated.
This is my first post! :)
Thanks,
--J
  • 1 year later...
Sorry for the bump, but is it still true that i can't put the tables into subfolders? some tables come with fpl files that have the same name and i can't put them both in the same folder.
You probably should have asked the question in a separate thread but I seem to recall I added support. If not it was zips I believe which will work the same for you.
i posted here because that's the first answer you find on google and it's the only answer i found that refers to subfolders, so for future searchers it might save some new topics.
anyway, you're saying i can add a zip? do i need to change something? or just put it in the tables folder?
  • 5 months later...
Hello,
I added some Future Pinball tables that doesnt exist in Visual Pinball. I´m using BAM, all goes fine but when exit from Future Pinball (I press ESC) it closes the table, but also PinballX, any ideas? I do the same with the others (Visual, FX2, etc) and only happens to me with  Future Pinball.
Thanks!
19 minutes ago, pindapoe said:
Hello,
Thanks!
You may want to post with your support files in the General forum.
  • 3 years later...
