Hi Tom
I now have pinballx setup to show real color dmd videos and images on the pin2dmd in the front end.
The log shows the atlantis table which i have set hide dmd to false in the database file to show the image while playing the table.
The first start of the table the image is displayed while playing but when exiting the table the dmd goes blank and stays blank even scrolling to other tables.
If i restart the table again the dmd stays blank while playing the table but when exiting the dmd comes back and functions normally. This repeats itself if you keep starting and stopping.
I can enter and exit a table without any issues if hide dmd for that table is set to true.
In the log file it looks like the not hide dmd line is missing from the first start of the table, also if i switch to use pinmame in frontend it works normally and the not hide dmd is there on the first start.
Cheers
log.txt PinballX.ini
Think it'll need Tom to look at, but a bit of a long shot for you - try disabling the dmd auto show media option and see if that makes any difference.
This line in the ini  - AutoShowMedia=True
I have tried your suggestion above and strangely enough it didn't seem to make any difference to how anything displayed on the DMD. Not sure if it is working either.
Cheers
