Good afternoon, I had version 5.28 working correctly and now when updating to version 5.32 the pinballx home screen appears and it jumps to the desktop, the dof lights stay on and in processes I have the pinballx.exe open, any ideas or changes What do I have to do? It happens to me on two different computers Thank you
I get the same with 5.32 (32 bit)
Log and ini attached.
log532.txtPinballX.ini
(i'm upgrading hardware on the cab so they ini probably won't make much sense as it's from a test install on desktop)
Error shown in log;
21:31:58.85  24/12/2021:  Loading Game Statistics and Scores
21:31:58.91  24/12/2021:  Loading Surfaces
21:31:58.92  24/12/2021:  Error. Exiting
21:31:58.92  24/12/2021:  Method not found: 'Void Direct2d.CFont..ctor(System.String, Direct2d.Device, System.Windows.Forms.Form, System.String, Single, Boolean, System.Drawing.FontStyle)'.
21:31:58.92  24/12/2021:     at PinballX.FrmMain.am()
21:31:58.92  24/12/2021:     at PinballX.FrmMain.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
21:31:58.92  24/12/2021:     at PinballX.FrmMain..ctor()
21:31:58.92  24/12/2021:  Disposing Plugins
Last good version appears to be v5.28
Download that for now via the download page and click the See changleog at the bottom next to the What's New label, select 5.28 then download option from there
EDIT - The X64 version of PinballX 5.32 appears to work ok (but i am using a different ini and media to test), so if you're on a 64bit windows version you could try selecting that in the install wizard options for 5.32 instead of rolling back to 5.28
  • Draco1962 changed the title to [RESOLVED] Fail Launch Pinballx 5.32
  • Draco1962 locked this topic
