Hi guys,
Is there a way to change the windowed mode resolution for the Model 2 application.
Daytona starts in a small windowed box. If I select switch to full screen its fine goes to full screen and the resolution is like 1080p, perfect.
However, if I leave it in windowed mode but enlarge the window so it takes up the whole screen the resolution is like 620p or something. Is there a way to make the resolution 1080p in the windowed mode so when I enlarge the window I get 1080p.
You might say just run it in full screen mode, but I can't. I am running two screens, and two players. So I need to drag one windowed application over to my second monitor. You can not run two full screen applications on one pc with two monitors.
It seems like it should be an easy fix but I can't figure out why the windowed mode is lower resolution.
Please, I know there must be a tech genius out there who knows how to do this.
Clues - I think its best to first understand where the model 2 application gets it window resolution from. Its like the emulator using a small resolution while in windowed mode and then switches to a higher resolution when entered into full screen mode.
          - In the GUI of the Daytona USA ++ Patch is a screen resolution select, but only for the fullscreen option
I think you are fighting against the emulator (assuming you experience the same issue running it outside of GameEx).
Saw your post also on Tom's Hardware. From there I saw a reference to Model2 UI that might be of help. You may want to post your query there as well.
http://forum.arcadecontrols.com/index.php/topic,159733.msg1680224.html#msg1680224
Thank you Draco. This could be the answer! I have edited the title to say Model 2, because I think you are right, its not Daytona that is the issue, its the Model 2 application.
  • tangodownNZ changed the title to Change windowed resolution - Sega Model 2
