Here is my current setup:
I have an Atari Fighting stick joystick console, I'm using for both MAME and Visual Pinball.  Inside it I built an Intel NUC, and I'm trying to use this without a keyboard if possible.
I'm having a problem with mapping keys to the buttons.  Basically, I map the keys I need in Visual Pinball preferences, and as long as I launch the games individually (double clicking the table.vpx) everything works.  But when I launch the game from within Pinball X , the mappings are completely overridden by the mapping from Pinball X settings.  That wouldn't be an issue (usually), but Pinball X doesn't have an option to map the flippers (none that I can find), and it defaults to the left and right arrows on the keyboard.
Moreover, it doesn't just temporarily overwrites the Visual Pinball mappings, it wipes them clear, so when I go back to Visual Pinball, under preferences, everything has been set to the Pinball X mappings, and since Pinball X does have any default button maps for the flippers and magna-saves, those mappings are now blank.
So Ho do I go about doing this, or do I need to get a 3rd party app to map my buttons?
One other thing, can the game selection scroller which is currently mapped Left and Right, be assigned to a trackball?   I have a spinner on the board, and it would be perfect for game selection.  The spinner basically behaves like a mouse or trackball that moves in the "X" axis only (left and right).
Try to set "auto configure" to "No" in the settings for Visual Pinball
  This will avoid to overwrite your visual Pinball settings from PinballX
I think that it is not possible right now, and should make a feature request for Tom
Thank you, I'll give that a try.
At the moment though, I think I solved the problem by using a 3rd party app, Joy2Key.  This app lets you assign keyboard strokes to the joystick and buttons, and you can create profiles based on each app.  So I created a profile for Pinball X, and another for Visual Pinball, and now everything works as expected.  But I will definitely try to disable the auto configure function and see if that helps.
Anyway, I will put a feature request in to Tom for the spinner.  I'm sure most users here have a cabinet setup, but I don't have room for one, so I had to settle for what I already have.  but that spinner, just begs to be used in the UI as the game selector.  It's free spinning, so a quick flick of the wrist could probably take me from one end of the list to the other. ;)
