Hello,  Im new to the whole pinball machine.   I made my own cabinet installed pinballx but im having a issue removing the instructions that come with the games or move it to another screen. Id rather just remove it all together  ( see attached pic) Its on my main screen right now.  Its the part at the top that says big game that im wanting to remove.
Thanks for all your help
Nevermind,  After just playing around with settings I changed the apron settings that was already on show apron = no  it was still showing so i moved it to another screen that i dont have and its gone!
Never noticed the apron screen being on by default in a new install. You could try changing the show apron = no to a yes, then exit settings.. go back in and change it back to no again. Might just be a missing line in the config ini and that should clear it as well.
For info, it's best to attach your copies of your pinballx.ini file (in the pinballx\config folder) and log.txt file (pinballx\log folder) when raising issues so we know more about your config.
Welcome to the hobby, enjoy!
  • Draco1962 changed the title to [RESOLVED] Removing Instructions
