nwwoods Posted July 7, 2021 Share Posted July 7, 2021 Just getting started with PinballX. I have several games working correctly in a Visual Pinball cabinet setup. Installed PinballX per instructions, went through Settings utility to get monitors setup correctly. When I launch PinballX, I can see the playfield, backglass and DMD screens load correctly. I see the PinballX logo in the center of the main display, followed by the sample game logo (Stern Big Game), and then it goes blank. I can hear a sound when I press L or R arrow keys, and a different sound when pressing ESC, but I have to Alt/F4 the app to terminate. Also note on startup, I briefly see a backglass image for the alphabetically-first of my Visual Pinball games on the backglass monitor. Surprised to see this as I have not added any of them with Game Manager, just trying to run with the sample data. Log seems to indicate it's stuck in a loop initializing the windows, so I am guessing there is something about the displays I don't have set right, but no idea what. Attaching config and log files per support guidance. There is no error log file. Note the "DMD" is just another small monitor on this particular system. Graphics is Nvidia Geforce GTX 750 Ti, which supports 3 monitors. Main is 1, DMD is 2, backglass is 3, and settings are set to match (see the .ini). I have reviewed the documentation and searched the forum for similar issues but unable to find any, so requesting help accordingly. log.txt PinballX.ini Link to comment Share on other sites More sharing options...
Mike_da_Spike Posted July 8, 2021 Share Posted July 8, 2021 I used your ini file on my test desktop (only changed the path of visual pinball to my VP directory and exe file) , but all working fine for me. If you remove the sample VPX file and add a real one (with just some entries), do you have the same results ? And just add media as well for your playfield, backglass and DMD. (with PinballX Databasemanager, you can easily create system files/tables files etc ) And the installation is done via setup I assume ? Not copied over any files ? Link to comment Share on other sites More sharing options...
Tom Speirs Posted July 8, 2021 Share Posted July 8, 2021 Its definitly a display issue. Do you have best drivers installed etc? Is there an app stealing focus. PinballX keeps trying to reset the display. It will do this if direct3d reported lost device or display settings change. 1 Link to comment Share on other sites More sharing options...
nwwoods Posted July 9, 2021 Author Share Posted July 9, 2021 > Is there an app stealing focus. That triggered me to unplug the VirtuaPin interface, and then it came up. So that's what's stealing focus. I had wired the coin door switch to be insert-coin (as the actual coin mechanisms have been removed), and that appears to have been a mistake. Using the VirtuaPin controller app, I can see that input is always on when the coin door is closed. Oops. Will come up with another insert-coin solution. Thanks! It also took me a while to realize I had to use L and R arrow rather than U and D to navigate the menu, so can quit normally now. Appreciate you asking good questions! Irony of the day: my cabinet is a repurposed Williams Road Kings, one of the samples. 1 Link to comment Share on other sites More sharing options...
