Hello, I'm trying to change background mode but it seems it doesn't work properly. I'm trying theme "ArcadeVGA Low res" I set "display black background" but I still have the videosnaps running as background.
I'm running 640x480 and although there is room to see the videosnaps in a corner of the screen, the preference goes automatically to show the videosnaps as backgorund. Is there a way to see the videosnaps in usual picture instead of to have it in full screen as background?
thanks
Its certainly possible. How to do it may vary based on the theme though. For most themes you would select change view until you get the view you like, is that not working?
Thank you very much!
Please could you suggest me the right menu where I can find “change view”? I’m looking through the setup wizard but I didn’t find the option.
Thanks!
Use the Search feature in Setup Wizard and enter change in the search field. Click the next button until you go to the page where Change View can be enabled/disabled.
  • Draco1962 changed the title to [RESOLVED] Background mode in different themes
