Greetings;
Thank you for providing PinballX. It is a wonderful program with the exception of this ONE thing.  :-)
I keep things as simple as possible. Once Covid is over, I will return to throwing a bunch of parties, and I want anyone to be able to walk-up and use my machine without having any prior knowledge.
My VP cabinet has playfield and DMD screens, but just a static translite.
The only PinballX media I use are Table Images and a Wheel Images. No audio, no video, no backglass images, no launch images, no exit images. ..
I have Show Additional Detail disabled.
I have One Click Launch enabled.
In addition to the standard pinball buttons my cabinet has  buttons for Volume Up, Volume Down, Pause and Exit.
If someone is playing a table, pressing the Exit Button should:
1) Exit the Table to the Tables Wheel
2) Exit the Tables Wheel to the Systems Wheel
3) Exit the Systems Wheel to the Operating System.
At the moment 2) is skipped.
I understand that if I were to disable One Click Launch, that there would be an option to return to the System Wheel. But that is not at all intuitive.
Thank you for your consideration!
   - Mark
