I just downloaded GameEx 4.01. Now when I start, the Menu doesn't have mame on it. It shows my SNES an Pinmame but not Mame. I have looked at the config file to make sure everything is correct and it seems to be. Does anybody have any ideas?
Hi,
The log file should explain why. Could you post it, if you cant figure it out?
Thanks.
Didn't think about looking at that. I figured out what was wrong, simple mislabled directory caused GaneEx not to find mame. Everything is up and running. Thanks for your help Tom.
P.S. This is the BEST frontend out there!
