I upgraded to a new computer and When I run the setup wizard, Every few minutes Gameex will reset itself, not giving me enough time for the choices I make.  Why?
Don't know. Can you attach copies of your gameex.ini and log.txt files for review? Thanks!
P.S. You may need to re-download the latest version and install over the top first, then provide the files requested above if the issue persists.
I'm not seeing anything that stands out in the log file. Have you checked in Windows Event Viewer for any log entries at the application level for the time the issue occurs?
OK several questions.  Can I run gameex from my d drive my c drive is pretty close to full?  So I have my directories set up as D:\Desktop\Gameex \GameEx  will  that work?
Next I keep getting kicked out of Gameex into the  Mame EmuMap management consistantly, so I cant even scroll through the pages in the wizrd setup.  It also doesn't list anything to do with Mame.
Thanks very much
Not sure what you are experiencing with the Setup Wizard.
Yes, you can run GameEx from another drive. Copy your GameEx folder to your D: drive, then download a fresh copy of the latest version and install over the top. This may also fix the Setup Wizard issue in the process.
Let us know how you get on.
