PinballX not directly loading 1 FX2 table - all others work fine
At my wits end not getting 1 table  ( FX2 - Football_Roma ) to directly load in PinballX 4.85.  It's the only table that loads to game select screen
All other 4 FX2 tables load directly to the table:  SplosionMan, PlantsVsZombies, SouthPark2, SouthPark1. All other systems work perfectly: VPX, FX3, FP.
I've tried renaming the table in the launch command via copy/paste. Tried deleting the table xml and re entering it into the Pinball FX2.xml  via Game Manager.
Tried enclosing the parameter[TABLEFILE] in quotes from  -applaunch 226980 [TABLEFILE] to -applaunch 226980 "[TABLEFILE]" in Settings manager
Tried setting the "waitfor to -1"  in PinballX.ini for [PinballFX2] even though I have read this is no longer necessary.  Log.txt says "Found Pinball FX 2 Process" So, I have no idea what the problem is.
I feel I've neglected something obvious but am too close to it to be able to see it clearly.
I have a 2 screen setup, no dmds, not running  any DOFLinx or PupPacks on FX except mp4  backglass, i5-4590; 16GB; GTX 1650
If someone gets a chance to glance at it, I'd appreciate it - if only to save my sanity.
log.txt PinballX.ini Pinball FX2.xml
Okay, just tried running via command line and went to table selection.  Must be a Zen thing, not PBX.
Moved all the other Football_x.pxp tables out of \data_steam and it wouldn't run unless Football.pxp was present along with Football_Roma.pxp
It must be using Football.pxp as the table and the additional table file as the 'skin' ?  Being a caveman, I have no idea what's going on, though.
I can't be the only one with this problem,  right?
just an idea but try making a copy of Football_Roma.pxp and name it something else than Football_XXXX.pxp like Kootball_Roma.pxp then use Kootball_Roma as tablename in game manager we have a similar problem with pinball fx3's mars table also make sure you own the table
Tried renaming with the same result.   I renamed it, copied it and renamed it. Nothing.
I've got a thread in the Zen forums, but it may not ever get answered since no one is using FX2 anymore.
This build is a fresh install of Win10/VP/FP/PBX  for a new cabinet, so I had this bright idea to check my already built cabinet to see what I've done wrong.  You know, because my older cabinet is perfect.
It seems I had this problem before and I just de-enabled [Football_Roma] in the XML.
