[RESOLVED] PinX is hiding my backglass/dmd images
So now that I've upgraded to the current PinX my 'hide backglass' 'hide  dmd ' tags don't seem to be working anymore.
I have the 'hide backglass' set to 'false' for a few VP tables that don't have a b2s and I have 'hide dmd' set to false for all my mame games so my marquee images stay visible.
Are these being handled a different way now?
Can yiu share your logfile (launch a table where vp table and mame game should show an static image) and also your pinballx.ini.
I dont use it, but will try it as well.
Vp table without a backglass ??? Can't recall that I have one.
Here you go. I can see in the log it's telling it to not hide but it's not working. Works fine on my old PinX install.
Yea I have a few old VP9 tables without b2s, I could lose them. It's keeping the Mame marquees on my DMD screen while playing that I really like.
log.txt PinballX.ini
Well I did another fresh install with the same result.
I'm spoiled by the look of the loading vids now so I guess my only option is to roll back to an older build.
Does anyone know when the loading vids option was added?
Loading videos introduced with 3.60
Ai ! You running w7. I know there where some issues with it. Thought there was someone with the same issue and he made videos from 1 frame.
If you import in Databasemanager a picture backglass or ayfield, it ask you to convert it to video. Try this once on a table, to check if you see the backglass
That's cool . Wijtkamp is their family name.
So I didn't have that Databasemanager installed (didn't realize it was an add-on) so I just copied one of my backglass vids into my dmd vids folder.
It showed up on the dmd screen and happy to report it stayed there when I launched the game!
So I guess Win7 is the problem and could be a work-around. If I can figure out how to make nearly 3000 png images into mp4's that is.
Incase anyone else has this issue I've found the program HandBrake works nicely for png>mp4 conversion.
Converting all my DMD images now..
Actually, Databasemanager is not an add on, but a standalone program.
Glad you figured it out. There are multiple tools you can use to convert.
Databasemanager uses ffmpeg from tbe pinballx directory
Sorry yes that's what I meant. I didn't install it but it didn't appear to be what I needed to convert a big batch of pngs to mp4.
HandBrake worked great. Time to do some actual playing. Then I'll dig into what else the new PinX offers..
  • Draco1962 changed the title to [RESOLVED] PinX is hiding my backglass/dmd images
