So im posting this just to give some ideas on how to do a dyi simple plundger. So basicaly i just put a pushbutton on normally closed so that the plunger pushes the micro, and that way release it to normaly open, so once you pull the the plunger, the pushbutton turns closed, and as you release the plunger and push the button, the button opens itself again , release the ball.  Do i make sense? is just english is my second lenguage and sometimes i have a hard time explaining things, but if theres enough interest, ill just post a better video on how its done.
  • Like 3
Suggestion: a parts list, a step-by-step tutorial with pictures along the way and a longer video.
What you have so far is good and it is grest that you came up with something that appears simpler and less expensive than commercial offerings!  Thanks for sharing!
  • ode1979 changed the title to Simple plunger from an arcade stick and a pushbutton
