Hey all. 80% of my FP tables are working perfectly..thank god! Getting this odd problem with about 8 of my tables. No problem with display resolution settings…
Any ideas perhaps? Thanks!
Hi there! A few things that may be if help to others attempting assistance:
- A list of the tables exhibiting the behavior
- Is the the behavior the same across all 8 tables?
- Did you open these outside of PinballX? Any odd  behavior or errors noted?
- Are you using Pinup Player for displaying tables and media?
- A must when reporting a problem no matter the nature. Attach copies of your pinballx.ini and log.txt files (from right after the errors occur).
Please answer these questions and provide the files attached in reply and pur panel of experts will likely provide superior service! Thanks!
Hey there! I actually reinstalled everything and got it up and running. Sorry for the fire alarm and thanks for the quick reply!!
  • Draco1962 changed the title to [RESOLVED] Future Pinball quick display question
