Hey all, not having this problem with any other tables just the AFM ones. Realdmdv3 lights up light a Xmas tree and stays that way. Hoping for some insight. Thanks!
Is thisonly when lsunching from PonballX, or also when you launch directly the vpx table ?.
What version of Freezy do you run ?
If you disable in vpinmame to use external dmd, and enable the virtualdmd. Is it showing fine ?
Did you try other afm roms ?
When I launch from both. Using afm_113b, and that appears to be the problem. How do I get it the table to refer to a different ROM? I’ve switched them out and reinstalled tables but keep getting ROM issues. Thanks!
Appears it isnt the ROM, but rather the Pup Pack I believe. Going to try to mess with it a bit...thanks!
  • Draco1962 changed the title to [RESOLVED] Attack from Mars-All tables- pindmdv3 issue
  • Draco1962 locked this topic
