Two maybe dumb questions.
ode1979
Hey me again , im sorry to bother you guys, but the search function did not brought anything.
#1.-  Where do i need to place the needed files to have images at system menu list. Example images for the list that start with the systems i have rather all the games, i dont see but the system logo, thats all. I can make my own videos for table and backglass, but i cant find where to put them.
#2.- its there a way to go back to the system list if i umsing the simplified menu instead of going to launch a table the choose systems?
example, like in hyperspin or any front end, (sorry i dont use gamex, i used to use it when it first came out) anyway, like in any front end, if you hit esc it takes you back to the system list, no need to go to a menu.
Thanks for any help.
Link to comment
Share on other sites
You know there aren't any stupid question. Only stupid answers exists.
1) pinballx\media\<system>\ contains your media directories. Playfoeld, backglass and wheel. For system, create a file - system -.<extension> (note the spaves!)
Using Database Manager (see download section) let you easily drag abd drop files for systems and other media content (also easy to go to the directory/file and get media from ftp/mega)
2) unfortunately there isnt a button to go back. Yiu can request this in the feature request topic
Link to comment
