Hi all,
I noticed yesterday that I got a pretty substantial update to Steam. I have all of the Pinball FX tables and up until this update, they have all be working flawlessly. However, since the update, I am seeing that after I open a few tables, they will start to load through PinballX, they will bring up the FX3 screen for a few seconds and then drop out to my desktop. If I do an Alt-Tab I can get back into the table and it plays fine. It will also exit fine. If I go to open another table it will do the same thing. Opening tables directly in FX3 works fine. Opening my Virtual Pinball tables through PinballX works fine. I have disable any run before and run after commands and those made no difference. The only thing I can think of is the update had something to do with this. Has anyone else run into this problem recently?
Thanks!
