Hi, I put it back.
All seems well so far, just need to configure how i want it.
at the moment, none of my backglasses (display 1) are showing.
Also playfield (display 2)on top and nothing on bottom, so i know i've done something wrong
if you need help on that, you need to attach you log.txt and pinballx.ini, so we can have a look.
Also be sure that in windows all is correctly setup.
Within Windows set your playfield to primary and all the way on the left, like this :
