I can't seem to find this option.
In settings - General Settings - Systems List - Show on startup = enabled
When PinballX starts - it asks what system you'd like to select.  In my case it would be Visual Pinball and Pinball FX3.  Cool.  Works perfect.  Except once you choose one, there is no way to go back to choose a different system?   You have to exit the frontend and reload.
Is that correct?  Is that intended?  Logically allowing the [exit emulator] keybind to do this makes sense to me?      The [quit] keybind just brings up the exit front end menu.
thanks,
So choose a system, then choose a game, then choose go back to systems.
Not very intuitive - in fact I would expect most folks to never figure that out.  Why would I try to start a game when my intent is to choose a different system?    Thanks for the explanation though.
And I guess if you have it set to not pull up the game menu and just launch it directly, you'd be stuck without ever getting the option.
Sorry, my mistake. My button called start. This will show the menu where you can start the table,  get extra info, but systems is in that list as well.
So indeed not the direct launch button.
If you dont have setup this button, you will not get to filters or custom database, recently added etc.
I have both buttons setup in my cab
Sorry for the wrong info I gave you
No worries.   Just trying to figure this stuff out.  In GameEx (on my arcade cabinet) there is a clear "enter system / exit system" functionality.    Strange that its not the same in PinballX, which is basically doing the same thing, just with a different presentation.   Maybe I'll do a feature request.
Gotcha. So you mapped the buttons to keys.
I use the buttons sifferent in pbx rhan in vpx.
Also have 5 buttons
Launch ball - Direct table start
Start - Select
Exit - Exit emulator/pbx
Coin - show instructions
Pause - Pause game
