I have two frontends on my cabinet. gameex for the media, books, music etc and i have 1 executable to the other frontend i set up in gameex. what happens is i  choose the program. start it in gameex then while the other frontend loads, gameex pops back up and continues. how can i get it to stay minimized and paused like it usually does with emulators until i escape out of the program? is there a command line i have to use? and if so, where do i place it? if anyone can help, id appreciate it. ini and log are included.
GameEx.ini log.txt
Edited by cnells2000
  • cnells2000 changed the title to Running another frontend inside gameex? .ini included
If i were to guess you are probably treating Launchbox as an emulator instead of launching it as a program.
You probably should try launching through Other Programs instead. You'll need to experiment.
Since Launcbox/Big Box are a competing frontend, this is further than I'd like to go to be honest.
ok i understand. but where is other programs section?
I misnamed the feature. Look through the Setup Wizard for External Applications.
