@Tom Speirs
Just a question about the new system "Custom - exe files"
I'm playing a bit with it and as I understand , I only have to fill in a name/Folder in settings  and thats enough (no path/executable or process to monitor, right ?)
Within Game List Manager, I can define the exe files :
When I use the direct Exe file all is working, but if I use Steam.exe, or another launcher (like in this example LaunchAstrobeer.exe), it will directly go back to PinballX screen and the game is laoded in the background.
Is this as designed, or can there also be a "Process to monitor" per game ?
Or does it work different ? (sorry for the stupid questions)
This was tested on my test PC (not on my cabinet)
log.txt PinballX.ini
Its as designed and there is no  new individual game options,. Its not for other launchers/emulators that is still done as it always has been as a regular "other" custom system.
