[RESOLVED] Can I run a png overlay while Daphne is running?
Can I run this png overlay while Daphne is running?
In MAME I've used this format with custom lay files but that doesn't work for Daphne.
I thought maybe a Launch Before or something?
Thanks in advance
My guess would be that if DAPHNE doesn't support it then, unless the frontend integrated support has a mrans of doing so, then no.
Thanks. I hate the thought of rotating, editing and rendering 194 videos but that may be the only way! What about a Launch after?
Also, is there a way to add to rotate these parameters?
lair vldp -fullscreen -x 1152 -y 864 -framefile "c:\Daphne\vldp_dl/lair/lair.txt"
No way that I am aware of. Tom might know something as he is more the expert here.
Since the functionality you are seeking is not part of the integrated DAPHNE support, your best bet at this point is to submit a feature request:
Hey.
Yeah, I can't think of any way to do this, at least within my skills. If it could be done perhaps via injecting into Daphne's OpenGL mode or perhaps an update to Daphne source code.
  • Draco1962 changed the title to [RESOLVED] Can I run a png overlay while Daphne is running?
  • Draco1962 locked this topic
