Bug in game manager leading to jit errors when using < or > character in description field
edit: forgot to mention was on older PBX when i noticed it, updated to latest version and problem persisted
Add a space and then < or > character at the end of the description of a table entry save the list and try to reopen the list. It will produce below jit error without being able to load the list again unless you manually modify and remove &lt; or &gt; text in the database file. The error that shows is "illegal characters in path"   I think using &gt; and &lt; is correct (to keep xml correct) but not sure why the illegal characters stuff pops up as i can easily create a file with &lt; or &gt; in the filename so not sure why i get that error.
I only found this out by accident and thought i should mention but i don't actually have a problem with it only mentioning in case other people might run into the problem and don't know to fix it to get their list back
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Illegal characters in path.
   at System.IO.Path.CheckInvalidPathChars(String path, Boolean checkAdditional)
   at System.IO.Path.InternalGetDirectoryName(String path)
   at d.e(String A_0)
   at d.a(String A_0, String A_1, String A_2, String A_3)
   at d.a(String A_0, String A_1, UserControl1 A_2)
   at Game_Manager.Form1.LoadSystem(String Sys, String File, String IniSysName, Boolean JustList)
   at Game_Manager.Form1.j(Object A_0, EventArgs A_1)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
see video to see what i mean
