Adultery Posted October 15, 2006 Share Posted October 15, 2006 If I was to understand the post about the new version (6.98 is what I have I believe) the bezels are supposed to work for vertical games, but not for me. My verts just fall back to the GameEx GUI unless I disable the bezel.Any suggestions? Link to comment Share on other sites More sharing options...
firebrand_X Posted October 15, 2006 Share Posted October 15, 2006 If I was to understand the post about the new version (6.98 is what I have I believe) the bezels are supposed to work for vertical games, but not for me. My verts just fall back to the GameEx GUI unless I disable the bezel.Any suggestions?Atleast you can get in. GameEx 6.98 freezes up on the Home page for me (details in the GameEx 6.98 post) Link to comment Share on other sites More sharing options...
hansolo77 Posted October 15, 2006 Share Posted October 15, 2006 I was able to get past the Home Page. I updated from within GameEx. I went into the MAME games menu but before I went further I remembered "I probably need to enable the bezel." So I exited GameEx and enabled the bezel. Then I went back into GameEx, then MAME games, then Vertical Games. It popped up an option at the point to update the game list. Ignorantly, I chose not too, and tried to launch 1941. It didn't work, and went back to GameEx. It's possible you have to rebuild/update the game list before the bezel artwork will work. I'm testing the theory by updating it now. It may also need to be directly updated from the website, and not updated from within GamEx. I'll report back if it works/fails. Link to comment Share on other sites More sharing options...
Adultery Posted October 15, 2006 Author Share Posted October 15, 2006 I already tried to rebuild the game list - no dice. Link to comment Share on other sites More sharing options...
headkaze Posted October 15, 2006 Share Posted October 15, 2006 I actually said yes to when GameEx detected a new version of Mame and did the update list thing, then I exited GameEx and turned on the Bezel feature went back into GameEx and tried 1942, but it went straight back to the game select screen. So I can confirm that there may be a problem with bezel feature. Link to comment Share on other sites More sharing options...
Adultery Posted October 15, 2006 Author Share Posted October 15, 2006 /me is glad to see he's not losing his mind. Link to comment Share on other sites More sharing options...
Tom Speirs Posted October 15, 2006 Share Posted October 15, 2006 There still seems to be issues with auto update. You need to do a manual install to get the bezel v2 filesYou dont need to update the list, thats just because GameEx now checks for a change in mame version, and as theres no history for the mame version for your install prior to this release it prompts.The exception problem is fixed in 6.99 now available.Thanks.Tom Link to comment Share on other sites More sharing options...
headkaze Posted October 15, 2006 Share Posted October 15, 2006 Tom: I did do a manual install of 6.98 and I have the same bezel issues as reported here. Link to comment Share on other sites More sharing options...
Tom Speirs Posted October 15, 2006 Share Posted October 15, 2006 Tom: I did do a manual install of 6.98 and I have the same bezel issues as reported here.Can you change the mamefilesize in gameex.ini under [internal] ,launch gameex, post your log, and check you have bezelversion=2 in gameex.ini under [internal]Thanks. Link to comment Share on other sites More sharing options...
hansolo77 Posted October 15, 2006 Share Posted October 15, 2006 I just my rebuilding/updating and came here to report. I didn't know more messages had been posted, but here's what happened. GameEx crashed! It went to a black screen for about 5 minutes. I had to ALT+CTRL+DEL to get out of it. I'm rebuilding it again now. Guess the Bezel problem still isn't fixed yet. I hope this didn't break people's setups that don't use the new bezel format.... Link to comment Share on other sites More sharing options...
Tom Speirs Posted October 15, 2006 Share Posted October 15, 2006 Yeah, I just finished rebuilding, and GameEx crashed! It went to a black screen for about 5 minutes. I had to ALT+CTRL+DEL to get out of it. I'm rebuilding it again now. Guess the Bezel problem still isn't fixed yet. I hope this didn't break people's setups that don't use the new bezel format....You all need to get 6.99, 6.97 and .98 are going to have crash issues.HK: Can you also check youve not got an existing bezel there. Link to comment Share on other sites More sharing options...
hansolo77 Posted October 15, 2006 Share Posted October 15, 2006 I erased the original bezel and replaced it with Mr. Do's once it was available. I'm going to just erase all the files in there, and reinstall it from the web.[EDIT] Just erased the files in /bezel/ and downloaded the latest install from the web. Installed it. Checked the /bezel/ folder and noticed there's 2. /BEZEL/ and /BEZELV2/ Both folders have files in them, where I had erased them before. Tried to run GameEx, mame, vertical, 1941.. it crashed back to GameEx again. Tried 1942 and 1943 as well. Still no go for me. Link to comment Share on other sites More sharing options...
headkaze Posted October 15, 2006 Share Posted October 15, 2006 Same thing happened, but this time when I tried 1942 I noticed it performed that exception error. So I'm going to update to 6.99 and see if that solves it. Link to comment Share on other sites More sharing options...
hansolo77 Posted October 15, 2006 Share Posted October 15, 2006 Just checked for HK on the gameex.ini too... I do have a line under [internal]:BezelVersion=2[EDIT] here's my log:01:58:59.9 10/15/2006: GameEx: Version 6.99: Starting Log01:58:59.9 10/15/2006: Operating System Platform: Win32NT01:58:59.9 10/15/2006: Operating System Name: Windows XP01:58:59.9 10/15/2006: Operating System Version: 5.1.260001:58:59.9 10/15/2006: Checking for versions of .net Framework installed01:58:59.9 10/15/2006: .net Framework 1.0 Installed01:58:59.9 10/15/2006: .net Framework 1.1 Installed01:58:59.9 10/15/2006: .net Framework 2.0 Installed01:58:59.9 10/15/2006: AMD Sempron Processor 2600+01:58:59.9 10/15/2006: 1.6Ghz01:58:59.9 10/15/2006: Running Randomize()01:58:59.9 10/15/2006: Checking for applications to Launch On Startup01:58:59.9 10/15/2006: Initialising Video/MNG DLL's01:58:59.9 10/15/20076: Running Misc startup tasks01:58:59.9 10/15/2006: Setting Menu types01:58:59.9 10/15/2006: Opening Configuration File01:58:59.9 10/15/2006: Getting Configuration Values01:58:59.9 10/15/2006: Using Theme: Default - Default - Animated01:58:59.9 10/15/2006: Checking for alternate Image Directory for Theme: Default - Default - Animated01:58:59.9 10/15/2006: Using Images from theme: Default - Default\MEDIA\01:59:00.0 10/15/2006: Launching HideOS.exe01:59:00.0 10/15/2006: Hiding Taskbar01:59:00.0 10/15/2006: Is Media Center running?01:59:00.0 10/15/2006: Checking/Creating LCD Registry values01:59:00.0 10/15/2006: Check Media Center Exit/Start Mode01:59:00.0 10/15/2006: Media Center Mode 201:59:00.0 10/15/2006: Text/Language: English01:59:00.0 10/15/2006: Applying Language/Text01:59:00.1 10/15/2006: Snap Delay set to: 101:59:00.1 10/15/2006: Get other settings01:59:00.1 10/15/2006: Set: Find emulator artwork on best match basis01:59:00.2 10/15/2006: Start work for Form01:59:00.2 10/15/2006: Getting Original Screen Size01:59:00.2 10/15/2006: Loading ICON01:59:00.2 10/15/2006: Initializing Component01:59:00.2 10/15/2006: Initialising Bass Audio Library01:59:00.5 10/15/2006: Loading default loading screen01:59:00.6 10/15/2006: Loading Custom Emulators01:59:00.6 10/15/2006: Loading Emulator 1: Atari 2600 Games01:59:00.6 10/15/2006: Loading Emulator 2: Atari 800 Games01:59:00.7 10/15/2006: Loading Emulator 3: Atari 5200 Games01:59:00.7 10/15/2006: Loading Emulator 4: Atari 7800 Games01:59:00.7 10/15/2006: Loading Emulator 5: Atari Lynx Games01:59:00.8 10/15/2006: Loading Emulator 6: Atari ST Games01:59:00.8 10/15/2006: Loading Emulator 7: Atari Jaguar Games01:59:00.9 10/15/2006: Loading Emulator 8: SNK Neo Geo Pocket Games01:59:00.9 10/15/2006: Loading Emulator 9: Nintendo NES Games01:59:01.0 10/15/2006: Loading Emulator 10: Nintendo GameBoy Games01:59:01.0 10/15/2006: Loading Emulator 11: Nintendo SNES Games01:59:01.0 10/15/2006: Loading Emulator 12: Nintendo GameBoy Advance01:59:01.1 10/15/2006: Loading Emulator 13: Nintendo 64 Games01:59:01.2 10/15/2006: Loading Emulator 14: Sega Master System Games01:59:01.2 10/15/2006: Loading Emulator 15: Sega Genesis Games01:59:01.2 10/15/2006: Loading Emulator 17: Sega 32X Games01:59:01.3 10/15/2006: Loading Emulator 18: Sega GameGear Games01:59:01.3 10/15/2006: Loading Emulator 19: StepMania01:59:01.4 10/15/2006: Loading Emulator 20: StepMania (Online)01:59:01.4 10/15/2006: Loading Emulator 21: Visual Pinball Tables01:59:01.5 10/15/2006: Loading Emulator 22: Future Pinball Tables01:59:01.6 10/15/2006: Using 3D Alpha Blended Animations. This could be slow01:59:01.6 10/15/2006: Using General Font: Trebuchet MS01:59:01.6 10/15/2006: Using Title Font: Trebuchet MS01:59:01.6 10/15/2006: Starting GameExtender Publisher01:59:01.6 10/15/2006: Initialising DirectDraw01:59:01.6 10/15/2006: Applying GameEx is Loading Image01:59:01.7 10/15/2006: Creating DirectDraw Device01:59:01.7 10/15/2006: Using Device: RADEON X800 PRO01:59:01.7 10/15/2006: Setting Resolution to 800x600 32 bit color01:59:01.7 10/15/2006: Creating DirectDraw Surfaces01:59:01.7 10/15/2006: Creating Primary Surface - Full Screen Mode01:59:01.7 10/15/2006: Creating Back Buffer01:59:01.7 10/15/2006: Loading graphic surfaces01:59:01.8 10/15/2006: Creating Surfaces Misc and Dialogs01:59:01.8 10/15/2006: Creating Surface Volume01:59:01.8 10/15/2006: Creating Surfaces Arrows01:59:01.8 10/15/2006: Creating Surfaces GameEXlogo Text01:59:01.8 10/15/2006: Creating Surfaces Toolbar01:59:01.8 10/15/2006: Creating Surfaces Backgrounds01:59:04.3 10/15/2006: Creating Surfaces Toolbar Controls01:59:04.3 10/15/2006: Creating Surfaces GameEx Logo01:59:04.3 10/15/2006: Creating Surfaces Home & Exit01:59:04.3 10/15/2006: Creating Surfaces Snaps01:59:04.3 10/15/2006: Creating Surfaces Menu and List Bars01:59:04.4 10/15/2006: Creating Fonts01:59:04.4 10/15/2006: Creating Menu Font01:59:04.5 10/15/2006: Creating Game Font01:59:04.6 10/15/2006: Creating Font Black01:59:04.7 10/15/2006: Creating Font Black Small01:59:04.9 10/15/2006: Creating Game Font Faded01:59:05.0 10/15/2006: Creating Title Font01:59:05.8 10/15/2006: Fonts Created Succesfully01:59:05.8 10/15/2006: MAME Path is: D:\!GAMES\_MAME01:59:05.8 10/15/2006: MAME EXE file is: MAME32ATXP.exe01:59:05.8 10/15/2006: ROM Path is: D:\!GAMES\_MAME\roms01:59:05.8 10/15/2006: Catver.ini is located at: D:\!GAMES\_MAME\_new\Catver.ini01:59:05.8 10/15/2006: controls.ini is located at: D:\Program Files\GameEx\data\controls.ini01:59:05.8 10/15/2006: History.dat is located at: D:\!GAMES\_MAME\_new\history.dat01:59:05.8 10/15/2006: nplayers.ini is located at: D:\!GAMES\_MAME\_new\nplayers.ini01:59:05.8 10/15/2006: MAMEinfo.dat is located at: D:\!GAMES\_MAME\_new\mameinfo.dat01:59:05.9 10/15/2006: Loading Controls.ini map file01:59:05.9 10/15/2006: Snap Path is: D:\!GAMES\_MAME\snap01:59:05.9 10/15/2006: AVI Snap Path is: D:\!GAMES\_MAME\videos01:59:05.9 10/15/2006: Flyer Path is: D:\!GAMES\_MAME\flyers01:59:05.9 10/15/2006: Cabinet Path is: D:\!GAMES\_MAME\cabinets01:59:05.9 10/15/2006: Title Path is: D:\!GAMES\_MAME\titles01:59:05.9 10/15/2006: Panel Path is: D:\!GAMES\_MAME\panels01:59:05.9 10/15/2006: Icon Path is: D:\!GAMES\_MAME\icons01:59:05.9 10/15/2006: Marquee Path is: D:\!GAMES\_MAME\marquees01:59:05.9 10/15/2006: MAME CMD options: -triplebuffer -nowindow -joy01:59:05.9 10/15/2006: Attempting to load game list01:59:06.2 10/15/2006: Loading last used Game List01:59:06.2 10/15/2006: Setting Music Volume01:59:06.2 10/15/2006: Creating DirectSound Device01:59:06.2 10/15/2006: Trying: Primary Sound Driver01:59:06.2 10/15/2006: Loading Sound Files01:59:06.3 10/15/2006: DirectSound Device Created Successfully01:59:06.3 10/15/2006: Creating ICONS01:59:06.3 10/15/2006: Restoring Cached ICONS from File01:59:06.6 10/15/2006: Initialising DirectInput for Gamepad support01:59:06.7 10/15/2006: Using Device PSX/USB Pad01:59:06.7 10/15/2006: Playing intro sound file01:59:06.7 10/15/2006: Initializing MCE Remote01:59:06.7 10/15/2006: Initialization OK! Starting GameEx!01:59:06.8 10/15/2006: Testing Main Loop Once: Processing Frame01:59:07.1 10/15/2006: Testing Main Loop Once: Main Loop ran successfully01:59:23.4 10/15/2006: Running: cmd.exe /c D: D:\!GAMES\_MAME\MAME32ATXP.exe 1941 -rompath D:\!GAMES\_MAME\roms -triplebuffer -nowindow -joy -artwork -artwork_directory artwork01:59:39.9 10/15/2006: Running: cmd.exe /c D: D:\!GAMES\_MAME\MAME32ATXP.exe 1942 -rompath D:\!GAMES\_MAME\roms -triplebuffer -nowindow -joy -artwork -artwork_directory artwork01:59:48.2 10/15/2006: Running: cmd.exe /c D: D:\!GAMES\_MAME\MAME32ATXP.exe 1943kai -rompath D:\!GAMES\_MAME\roms -triplebuffer -nowindow -joy -artwork -artwork_directory artwork01:59:55.6 10/15/2006: Exiting GameEx!01:59:55.6 10/15/2006: Saving Settings01:59:58.3 10/15/2006: Checking for applications to Launch On Exit01:59:58.3 10/15/2006: Media Center was not open when starting GameEx, so not launchingIt does look like it's trying to run with the artwork... Maybe GameEx is reporting the artwork path incorrectly? Link to comment Share on other sites More sharing options...
Adultery Posted October 15, 2006 Author Share Posted October 15, 2006 Updated to 6.99, updated my gamelist, launched a vertical game. It took GameEx a long time (like 30-45 seconds) to drop back to the GUI. Still bezel problems here unfortunately... Link to comment Share on other sites More sharing options...
headkaze Posted October 15, 2006 Share Posted October 15, 2006 Yeah I just did an update to latest version (6.99) and still same issue with me. GameEx.ini has BezelVersion=2 under [internal] and there is a folder called BEZELV2 in the MEDIA dir. I'll post a log if need be. Link to comment Share on other sites More sharing options...
Sterf Posted October 19, 2006 Share Posted October 19, 2006 I'm on version 7.01 and still having issues. I had to change BezelVersion=1 to 2 in gameex.ini for vertical games to load, but they still don't show any bezel. I'm not sure what else I can try. It also seems to go back to bezelversion=1 when I try to change some settings in gameexconfig.Great piece of software by the way.edit: It's also always asking me to update the gamelist, I've done so a few times by now (by accident mostly) but it keeps asking.Oh, and a side-question: MAME games don't have any last played info, was that always so or did I just only now notice it? Link to comment Share on other sites More sharing options...
Adultery Posted October 19, 2006 Author Share Posted October 19, 2006 If you're using old artwork files instead of the GameEx bezel, open one of the .zips (for 1942 perhaps).If you downloaded these before 0.106 you'll note that the artwork has a .map file with it. The new MAME (0.106-current) uses a .lay file instead of a .map file to display bezels. If you remove your artwork path in mame.ini and remove it from gameex setup, you should see Tom's bezel.The GameEx program asks you to update your game list each and every time you make a change to MAME. It's recommended you follow this through.I think you can enable/disable the last played game feature in the Advance Configuration.Hope that helps. Link to comment Share on other sites More sharing options...
emphatic Posted October 30, 2006 Share Posted October 30, 2006 GameEx ALWAYS changes my bezelversion to 1 if I change ANYTHING using the Advanced Configuration app.And then asks if I want to update the gamelist even though that doesn't help, so then vertical games doesn't work until I manually go to gameex.ini and change the bezelversion to 2 again. Clearly a bug here, Tom. Is there a setting to make GameEx not mess with bezel-settings? Or in the next version?Emph Link to comment Share on other sites More sharing options...
hansolo77 Posted October 31, 2006 Share Posted October 31, 2006 I've not seen this.. did you do a direct download of the 7.02 version? I believe Tom mentioned the autodownloader still doesn't work right yet. Link to comment Share on other sites More sharing options...
