I am trying to make an instruction card but the top and bottom are being cropped. So is there a standard size or ratio of like, 1000x500 or something. I would not ask such a thing but making the card the right size will take forever if I do know this.
You may want to try searching through the  User Projects and Media subforums. I came across these topics using the following Google "site" search using the following in the Chrome search window (not the forum's which can be a bit cludgy) - site:www.gameex.info/forums instruction card
I was not able to find any standards and they may vary, I would suggest accessing the FTP for @Carny_Priest's instruction card files to see if you can determine the dimensions from the image size, otherwise, send him a PM as he is the resident expert for all things Instruction Cards.
