Hi again,
Tom discovered the problem with the Mame list showing every game and it was solved with the latest update. Now my Neo Geo games (except for two: irritating maze and Kizuna Encounter) are not being detected.
The set is a up to date 0.220 Set. Should be fine I think.
Attached you find the files to check if something is wrong on my end.
GameEx.ini log.txt
Okay nevermind. I did an update to a 0.221 set. I would be nice if the dependency on the very latest set wouldn't be so high, if that's even possible. Most of the time barely anything in the set changes.
Best regards and sorry for the the fuzz.
Forever at the mercy of the latest emulator updates it seems. Glad you were able to get it sorted.
I didn't think that a 0.001 version difference would be a problem, but yeah, it was :D
Thanks!
