I am attempting  to configure GameEx Arcade to launch Pinball FX3
I was reading a past article (linked below under Pinball FX3 Setup) on how to configure GameEx for this, however the Arcade Edition options do not appear the same for this procedure.
I'm assuming that I can add it in as a PC Game similar to this article ("Add a PC Game on GameEX" linked below) .. but then how do I select an individual table?
Any help here is appreciated.
The second quote is for PinballX setup and not relevant to what you're attempting in GameEx Arcade.
Launching via GameEx and GameEx Arcade will be almost identical for either, yet because Pinball FX2 and FX3 are launched as individual programs via Steam, this will be a bit more difficult at the individual table level and the instructions in the first quote will not work as they are noted.
Beyond trying to launch an individual table, is there a way to just launch Pinball FX3 (aside from linking it up from the Steam menu)?
I was thinking to use the emulator setup menu, and simply point at the Pinball FX3.exe file.
You could try  that or using the first option you linked which would leverage using the shortcut file (.lnk) to launch Steam and the Pinball FX3 executable.
Unfortunately I do not have a copy of Pinball FX3 to experiment with on my gaming rig as it is licensed on my pincab installation and use through integrated PinballX support.
