This subject has already been mentioned.  But it was closed without solution.  The problem is that the video from the backglass is brighter than normal.  If I play the video outside of pinballx the brightness is correct.  But in pinballx it's too bright.  Playfield video does not have this problem.  I used different parameters in the NVIDIA driver, but it doesn't work.
Likely it was closed after several months of inactivity with no response.
Please attach copies of your pinballx.ini and log.txt files and let us know if you are running LAV codecs.
I managed to fix the problem by adjusting various parameters in the nvidia driver and the color profile parameters of the screens.  I don't remember exactly what I did, but now it's working normally.  But I still don't know why this problem only occurs on the backglass screen.
No clue. Could be an affinity  thing, where the primary gets preferential treatment? Mother likes the playfield best? IDK :P
Glad you were able to sort it out!
