System Logos Animated
View File
Well, since I really liked the animated logos of manufacturers that scutters have made, I decided to do the same or something similar with the system logos.
These system logos are exclusively exclusive to the Details Area, when PinballX allows different images for the Details Area and the Systems Menu.
In the systems menu, Megaballs or MegaDocklets or even Nuke Wheels are better.
Megaballs or MegaDocklets do not look good in the Details Area due to their circular shape.
Nuke Wheels look good both in the Details Area. like in the Systems Menu, but when converted to .gif to make them animated, they lose quality and can also show flaws in the animations, those flaws are much appreciated when PinballX extends them to show them in the Systems Menu, however, by reducing them for the Deralles Area, they are priceless.
My idea is to use the Nuke Wheels, either static or animated in the Details Area and the Megaballs or MegaDocklets in the Systems Menu, but PinballX still doesn't allow this.
PinballX at the moment, shows the images that you put in System Logos, both in the details area and in the Systems Menu.
I hope that some update of PinballX allows us to put as - system -.png in the Wheel Images folder of each system, the image that we want to see in the Systems Menu, as we do with the rest of the files, Backglass, Playfield, DMD, Audio or Topper.
Bueno, pues como me ha gustado mucho como quedan los logos animados de fabricantes que ha hecho scutters, he decidido hacer lo mismo o algo similar con los logos de sistemas.
Estos logotipos del sistema están exclusivamente exclusivos para el Área de Detalles, cuando PinballX permita imágenes distintas para el Área de Detalles y el Menú de Sistemas.
En el menú de sistemas, quedan mejor las Megaballs o MegaDocklets o incluso los Nuke Wheels.
Las Megaballs o MegaDocklets no quedan bien en el Área de Detalles por su forma circular.
Los Nuke Wheels quedan bien tanto en el Área de Detalles. como en el Menú de Sistemas, pero al convertirse a .gif para hacerlos animados, pierden calidad y también pueden mostrar fallos en las animaciones, esos fallos se aprecian mucho cuando PinballX los amplía para mostrarlos en el Menú de Sistemas, sin embargo, al reducirlos para el Área de Deralles, son inapreciables.
Mi idea es usar los Nuke Wheels, ya sea estático o animado en el Área de Detalles y las Megaballs o MegaDocklets en el Menú de sistemas, pero PinballX todavía no permite hacer esto.
PinballX de momento, muestra las imágenes que pongas en System Logos, tanto en el área de detalles como en el Menú de Sistemas.
Espero que alguna actualización de PinballX nos permita poner como - system -.png en la carpeta Wheel Images de cada sistema, la imagen que queremos ver en el Menú de Sistemas, tal como hacemos con el resto de archivos, Backglass, Playfield, DMD, Audio o Topper.
For some reason when uploading them here, they show faults in the preview that they don't really have.
Tomorrow I will be able to test them on PinballX, if someone can do a test today, it would be great since I could solve any problem before.
This .zip have the 10 system logos finished (not tested)
System_Logos.zipFetching info...
This logo its perfect for Systems Menu.
I hope that someday we can have MegaBalls, MegaDockets or animated logos like the one you just showed, in the Systems Menu, there they are great.
These images PinballX should look for in the Wheel Images folder of each system with the name - system -.gif or - system -.png.
But those types of circular images do not look good in the details area.
For the details area is when you should look for the images in the System Logos folder each with the corresponding system name.
As I have seen failures in the logos that I have prepared, I am making these other types of images for System Logos, with the idea of someday being able to see them in the details area and continue using my Megaballs in the Systems Menu.
I did tests on the cab, but I don't have all your systems.
The Visual Pinball has some pixels under the 'B' that is annoying. And I should remove the empty frames (that's what I should do) from the begin or end
Zaccaria, Pinball Wicked and Pinball Arcade looks awesome on the cab !
for the FX3, I prefer my own one (sorry)
But really like them !
Thanks Mike.
To test don´t need sistems, only rename the gif and test.
But this images isn´t for Wheel, this images are for details area (when PinballX allow use diferent images to details area and wheel sistem menu)
  On 6/6/2020 at 1:13 PM, PcTeknic said:
Thanks Mike.
Yes, I don't use them in wheels, but in the details and system menu
