Hi;
I am building a cocktail arcade, and have been working on the Gameex arcade.  Trying to get it set up to ONLY show Mame games --to make the frontend otherwise invisible.  Also, need it to run in cocktail mode--so do I flip the screen 90 degrees in mame, or in Gameex?  I am hoping that cocktail mode will allow 2 players to play on opposite ends of the arcade (so screen auto-flips for player 2).   I tried running only mame64, and it is less desirable than the Gameex choices...
I'm trying to minimize everything to make it easier for family members to play without having to make a lot of extra choices.  need to be able to get it to play mspacman without a lot of intervention...
I'll look forward to your thoughts & thank you!
nevermind--figured out that there was a menu item to run Gameex arcade mame only--and that I had to rotate the screen in Gameex, then to go in and both set roms to cocktail and rotate 90 degeres in the dipswitches for each individual game--works swell.
Please close/delete this thread!
Glad you found what you you were looking. Thanks for sharing your solution!
