Hi All,
I use GameEx Arcade on my PC connected to a CRT TV using Groovymame.
When I attempt to run games on Groovymame I have no sound but on the others emulators, dosbox and Scumm, I have no problem.
If I run the games directly from the groovymame interface they run correctly with sound.
In the attachment you find the ini file.
I am getting crazy with this issue.
Thank you for your help.
GameEx.ini
Im not sure why GameEx would cause an issue with it perhaps the combination of Windows 7 but your using Port Audio with GrrovyMAME which is kind of an advanced setting. Not that it is bad.
Try changing:
sound                     portaudio
to
sound                     dsound
or
sound                     auto
xaudio may also work which is better performing than directsound.
I believe I have tried port audio myself before and didn't have that issue but it was windows 10.
I solved with this configuration:
sound                     portaudio
audio_latency             0
# PORTAUDIO OPTIONS
pa_api                    "Windows WASAPI"
pa_device                 auto
pa_latency                0.003334
Thank you so much for your hint, you gave me the idea where to look.
  • Thanks 1
