Hi, I need help with setting up mame on retroarch with gameex.  On game setting in gameex I put :
Mame Path:C:\Users\wilso\AppData\Roaming\RetroArch
Mame exe: retroarch.exe -L "C:\Users\wilso\AppData\Roaming\RetroArch\cores\mame_libretro.dll" "[ROMPATH]\[ROMFILE]"
mame does not show up on gameex.
Please attach copies of your gameex.ini and log.txt files for review (no copy and paste of the contents). Thanks.
  • 1 month later...
How you are attempting to run this cannot be resolved. You are attempting to run MAME via Retroarch via the integrated MAME support - this will not work as it is optiimised for use with official MAME builds only. You will need to set it up within one of the available emulator slots.
As I do not run MAME via Retroarch, I am afraid I cannot be of help in standing it up via one of the emulator slots. Perhaps someone that has MAME setup in that manner can assist.
The only reason Why I run mame via retroarch is because of its amazing crt shaders that make's mame look like a crt tv or crt arcade monitor. Mame standalone HLSL setting is garbage compare to this. I don't like retroarch UI because it does not organize games as neatly as gameex and the screenshot pictures of games is too small.
