This is my first post and giving thanks to all the team for this lovely solution.
I was reading this post regarding TPA and Pinballx and how to start directly.
https://www.gameex.info/forums/topic/18792-pinball-arcade-direct-table-launch-with-free-camera-mod/page/6/
Done all the steps, with and w/o ahk, Pinballx launch the table...but its imposible to get ESC and return to PinballX, I have to do it with mouse. Any solution got?
i use ESC in pinball arcade + freecammod without a problem although i do run pinballx elevated but not sure if it's needed. If i remember correctly freecammod also runs elevated or at least needs it and sometimes programs with different elevation level can not communicate with each other. so just try to run pinballx elevated and see what that gives. Send/postmessage api for example does not always work then i've observed it at work also
edit: so basically try this: quit pinballx if it starts automatically at windows startup, goto explorer and locate pinballx.exe right click and choose run as administrator and try again your tpa / freecammod with esc key exit (given you had set esc to quit emulator key) if it works edit the properties of the exe to make it always run as administrator io elevated
