I can't seem to get FCE to return me to GameEx when done like MAME does. Are all console emulators similar to this issue adn I need to have a keyboard present? MAME is perfect.
It may be a simple change but we will need you to attach copies of your gameex.ini and log.txt files to review.
I have what I think is the right config to exit on ESC (note I am not pressing ESC on teh keyboard though, I am using joy buttons, which
EDIT: Ok, so you got me looking in the ini. Lead me back to the GUI config.
The emulator itself wont' exit with a button, but I did see in the Emulator setup, the Map back key was set, then digging more, I found the GameEx custom input for Joystick global back, and it was a weird combo, so I changed to my "back" button I use for GameEx and it now exits the emulator. I guess since MAME always worked, I never messed with this setting til I dug deep.
Soo....yeah, thanks for the response Draco, you got me to do some more digging at least!
So all working now I take it?
Your experience reminds me of a conversation I had with my son about computer vs. consoles.
I told him if you want plug & play, stick with consoles. If you want plug & pray (and swear and curse) stick with PC.
Feels good to roll up the sleeves and dig once in a while.
Exactly. After staring at things forever, I often call my peers and go over it on the phone and usually that is when it comes to me and I figure it out, just talking it out gets the mind flowing!
All good, working great.
