Inside the folder: ....... \ MEDIA \ LOGOS
I added the logos to be used by me.
right after installing gameex there are several of these logos inside that folder. As I wanted to customize my own logos, I deleted most of them and inserted mine.
I realized two things:
1st) The files I deleted still appearing their names there.
2nd) I added a file called "dreamcast". At some point I changed that name to "DREAM CAST". It turns out that there are now two names in the LOGO field. One with the name "dreamcast" and the other with the name "DREAM CAST".
It is not a problem that gets in the way but if it can be corrected it is always welcome right.
log.txt SetupWizard.log GameEx.ini
4 hours ago, Tom Speirs said:
Hi,
Sorry, I am  not quite sure what issue you are describing here? Probably lost in translation.
in short. The files that are inserted in the "LOGOS" folder remain with their names in the LOGOS field within the GameEx settings.
Example:
If I add the files named: "1", "2", "3", "4" and "5", when I enter: ("SetupWizard" / emulator configuration / Logo) we will see these five files.
And if we go to the LOGO folder and delete these five files, when we go back to ("SetupWizard" / emulator configuration / Logo) they will still be there ...
58 minutes ago, Tom Speirs said:
I believe it is because it looks in the default theme folder too. Simple as that.
I did not understand. I created my own theme from a standard theme.
you were right TOM. I removed the folder within the default theme and those names are gone.
But should this really happen?
Is there no way for gameex to focus only within the theme we choose to work on?
GameEx will look in the default media if the theme does not have the file it is looking for. Just how it works.
