Hello all.  First of all, thank you in advance for any help getting this figured out.  I've been trying to figure this out all day and I'm finally swallowing my pride.  Ran led blinky config, got everything set up the way I want for my cab.  Everything is working fine with my LEDs except for when I put it into jukebox and start playing songs my LEDs aren't lighting up at all...  I've checked that I enabled my speakers as my microphone.  It'll play and light up fine while in the led blinky config app but won't when I go into game ex.   Any help from you experts is much appreciated!
Please attach copies of your gameex.ini and log.txt files in addition to your LEDBlinkyControls.xml file for review.
Depending on your setup, you may need reach out to @arzoo as he is the LEDBlinky author.
First of all Thank you for replying Draco.  I'm not sure how to get my gameex.ini.  I'm not sure if its the gameex config file or what.   and the log.txt files are a mystery to me as well.  Its a miracle that I've even gotten my Cab this far.  But I think the issue was user error...<_<  I was expecting the lights to turn on when I went into Jukebox and they would not from my music, that was until it went into screensaver mode.  Once I saw that it was working there, I figured it was definitely something I didn't have checked.  I had to got into audio tab and set up the (can't remember) Frequency mode where you choose the 4 colors to use.  I went ahead and chose black as my first color (which is off) and then assigned 3 other colors after that.  I then had to check mark the box "FE Active Animation" box so that audio animation is always on while I'm in Game ex.  Now its acting as it should with the audio animation always on.  Thanks for your time and if anyone wants to tell me how to get my gameex.ini file or log.txt files, it might help me in the future when I get stuck again.
:cheers:
Look under
\gameex\config for gameex.ini
\gameex\logs for log.txt
The LEDBlinkyControls.xml file is under wherever you have LEDBlinky installed - typically under \gameex\plugins\ or \gameex\plugins\LEDBlinky.
