[RESOLVED] PinballX Loading different VP versions
Sorry Tom i dont know how that got posted,
Do you know how to run both .vpt and .vpx  tables in pinballx . if i use VPinballX as my .exe in setup all my .vpt tables are way oversized so i only see half the table
There are 2 ways:
Make for vpt file a seperate system and use the correct exe for vpt files.
Or if files are in the dame directory, you can use alternative exe tag:
Maybe there is a 3rd way, but I dont know that one.
Btw. In Database manager, we add the alternative exe tag in the gui
