As above really. when i first loaded up all the emulators, retroarch initialy set my 8bitdo controller as the binding for player 1. And my ultrastick 360 was only used for mame. this was perfect for me. controller for consoles, arcade stick for mame. But randomly it now has swapped the controller to ultrastrick on the consoles. ive gone into retroarch and swapped it over, saved it. but when i go back into game ex and load a game it reverts to the joystick. Any help would be great
Please locate and attach copies of your gameex.ini and log.txt files in reply to this post.
Log doesn't show any attempt of launching the said emulator.  Perhaps you need to save your config for that emulator and have it run from command-line.
HI, i deleted all my retroarch emulated options, reset it up. worked perfect. setup bezels. then randomly swapped again. At a loss what to do.
I think i have a duff 8bitdo controller, windows sees the controller but it fails to respond. i went into steam independant of gameex, and loaded a game, pad recognised unresponsive in game
