 Hi!
Will you have to start all VPX tables in the vpx editor and config the DMD and backglass or will PinballX do that for you?
You need to setup the screenres.txt to setup the backglass position once.
Yiu need to have a vpx, sirectb2s and corresponding rom file for the table.
If this is working fine, you can use gamemanager or database manager to add to the frontend
Ok thanks, the DMD is working and the Backglass is working when i'm in PinballX but when i start a table the backglass turns off but the DMD still works fine...
